Require Marking On Parts Of Welded Water Column?
I want some clarification as per PG-11 - Standard Pressure Parts,
That if anybody built welded Water Coulm as per PG-11, and if there was no any markings (Heat #, Matl spec.  etc..) on all welded standard parts (Like Caps, Ring- Joint, extenders etc.), than is this acceptable or not?
As per PG-11.3, no Matl. test report, MDR, inspection etc.. require.
Can we accept this welded water column without markings on all std. welded parts?
Pls. i need calrification/Guidence ASAP.
Mihir55
