Machine Screw Dimensions
I'm trying to find dimensions for machine screws defined within ANSI B18.6.3. Mainly Phillips drive (cross recessed) are the ones I'm interested in. I have Machinery’s
Handbook 26 but it has dimensions for slotted machine screws.
If anyone has any reference material showing the dimensions of phillips head machine screws (82 and 100 degree flat head, pan head) it would be of help.
thanks.
thanks.
RE: Machine Screw Dimensions
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
Here is some information:
Torq-set Recess
NAS1151-1158, 2903-2910
NAS1580, 1581, 1972-1980, 1992-2000
Heckler
o
_`\(,_
(_)/ (_)
The dimensions for phillips flat head machine screws are the same as for slotted. Try the following website...
http://www.barnhillbolt.com/
These guys keep good drawings online. They even have good drawings of metric pan head (cheese head?) screws.
JHG
that Barnhill bolt site is quite good. thanks JHG for the tip.
You will have to look to get fasteners made to this standard as most are now imported. It has been my experience that there is considerable difference in head height and slot depth on imported fasteners in the US.
http://www.smithfast.com/trussrndfill.html#round
If the matter is critical, it may be necessary to work directly with the manufacture to produce what you expect. If the matter isn't critical, then perhpas its not someting worth worrying about. :)
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
