Are there Different standards for valve & flanges?
Dear members,
I have a confusion albiet a silly one,but anyway here goes:-
Can we use a same standard for valve as well as drill standard?Are there any standards which specifies both valve as well as drill standards?Thanks in anticipation.
RE: Are there Different standards for valve & flanges?
My question is meant only for Butterfly valves only,Thanks in anticipation.
What I meant was:-
Now for eg:- AWWA Standard is a valve standard and ANSI is a flange standard i.e you can have a butterfly valve with MULTIPLE drill(for flange connection) standards at a same time i.e ANSI,JIS5K,JIS10K but the valve is based on AWWA.My confusion here is who decides the final arrangement,the end user or the manufacturer?
I don't have a copy of AWWA valve standards so this is purely my opinion. But, if the vendor is set up to supply you with different flange sets (ANSI,JIS5K,JIS10K), I doubt there would be any problems.
I'd pose the question directly to them.
navnit
