Galling resistance of AL6XN vs C276
Our current design uses a C276 nut on a AL6XN threaded rod in a seawater environment. I am looking at replacing the C276 nut with a AL6XN one but am concerned about galling. Does anyone have experience with AL6XN fasteners or know where to find more information?
RE: Galling resistance of AL6XN vs C276
Why are you looking to change?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
I would try to get a hold of Allegheny Ludlum , the daddy of AL6XN, and see if they have some data on galling.
http:/
I have always used C276 nuts since I could by them out of stock and not order specials. Look into having your bolt threads made by rolling. There are a lot of small roll houses around that would make a small run. I think that you will like the results.
Rust never sleeps
Think you sat in on my NACE paper last month in Nashville. Alloy 31 in phos acid. Thanks for the positive feedback.
