Part Visualization disappears
When building a multiple pad/pocket/pattern body in a associative assy.  After an update from a certain pad down all the parts visualizations disappear, if I double click on a later pad/pocket all the missing parts appear until I click OK, then disappear. Later associative links are still in place but, the parts can not be seen normally or when swap visual space.
Any help would be greatly appreciated.
Jeff
RE: Part Visualization disappears
Quote (engjeff):
What is your Catia version, operating sytem, etc.?
What type of hardware are you running? (specifically graphics card)
Catia Design|Catia Design News|Catia V5 blog
In your part, go to the Body with the features that aren't being displayers and right click on the body and select "Define work in oject"
that should bring back your features.  I think I have an identical problem with pocket features sometimes.  I can't explain why, but that tip above works for me.  Let me know if it works for you.
Thank you CPosner worked perfectly!
It would be really great if you could answer my previous question for the benefit of others who may have the same problem.
If you could provide your operating system and Catia version information, perhaps this question could be determined to be a bug, or version specific. (and there may be a fix available)
Thank you.
Windows XP-32 Pro
Catia V5R16
ATI X850XT
4GB RAM
Core2 E6700
I use V5 R17 SP4. Latest Release.
