Pressure Relief Valve Testing
Have need to test some "Bunsen" type relief valves built into battery cells.
Rating is a bit above 3 atmospheres and size is about
2 - 3 mm diameter.
Pretty much a rubber cap pressed over a formed plastic nipple and held in place by the external case.
Baratron is available and associated regulators for gas flow and pressure.
Looking for some actual test data curves from this type
and size of relief valve for comparison and reality checks on our data.
Best
George
