Stuck in a command
Stuck in a command
Somehow In all the chaos I am unable to escape from a command that I'm in. I get the popup:
"The current operation cannot be interrupted or the document is not accessible at this time"
I'm in an assembly and most of the commands on the toolbars are greyed out. I can't rebuild, and right clicking doesn't give me any useful options.
Any ideas what I might have done?
Specs, Intel Pentium M 2.16 Mhz
SW 2007 R2.2
1.5 Gb Ram
NVidia GE Force GO 6800 256Mb
RE: Stuck in a command
What is showing in the command line at the bottom LH corner of the screen?
Is any part in the FM tree in edit mode?
Have you tried exiting the sketch?
Exiting the feature?
Ctrl Q?
Hitting the Esc key several times?
SW07-SP3.1
SW06-SP5.1
Under defined and editing assembly.
The FM Tree looks normal. There is no feature properties pane on the left hand side. (Could that become hidden somehow??)
I don't have the option to exit the sketch or rebuild. Ctrl + Q didn't do anything and hitting Esc several times just brings up the error window I mentioned before.
I was working on an explode operation before this happened but I don't have any options at all in the configuration window.
Cheers
SW 2007 R2.2
1.5 Gb Ram
I don't remember the exact verbiage of the error message I get... but that has happend frequently to me.
...but try C.B.L.'s solution first.
Windows XP / Microsoft Wireless Optical Mouse 5000
SolidWorks 2007 SP2.2 / SpaceBall 5000
Lava Lamp
www.Tate3d.com
"Right-click... It's friggin' magic!" ... Jack L. Tate
FAQ376
SW07-SP3.1
SW06-SP5.1
[URL=http://imageshack.us][IMG]http://im
SW 2007 R2.2
1.5 Gb Ram
Cole M
CSWP, CSWST, CSWI, CPDM
SW06
SW07
IBM T42p, 2g proc., 1g RAM,ATI Mobility Fire GL T2
HP XW4100, 3g proc., 3g RAM, Nvidia Quadro 980 XGL
HP XW4300, 3.4g proc, 2.5g RAM, ATI Fire GL 3100
SW 2007 R2.2
1.5 Gb Ram
I'd done an exploded view of the shafting in my assembly, then I animated the collapse. After the animation is done I am stuck.
So I guess the question is, after you animate a collapse what do you have to do next to get out of that state.
SW 2007 R2.2
1.5 Gb Ram
SW07-SP3.1
SW06-SP5.1
Are you leaving the "Animator" open after collapsing the exploded view?
SW07-SP3.1
SW06-SP5.1
Advanced show/hide, show preview, go to, collapse items, and Customize menu
Which "Animator" window are you taking about? Is there supposed to be a pop up control bar? The only options under the Animation toolbar are screen capture, and Customize menu.
SW 2007 R2.2
1.5 Gb Ram
SW07-SP3.1
SW06-SP5.1
I get no animator tool bar popping up. I moved all my windows around to see if it was hiding behind but there's no sign of it. Very Curious.
SW 2007 R2.2
1.5 Gb Ram
http:/
SW07-SP3.1
SW06-SP5.1
But when I animate my collapse it is nowhere to be seen.
SW 2007 R2.2
1.5 Gb Ram
You may need to do a repair of your SW install to fix the problem.
SW07-SP3.1
SW06-SP5.1
Thanks for all the help as usual.
SW 2007 R2.2
1.5 Gb Ram
