weld bead erroring out
Good afternoon, I have a .256 dia hole in a flat surface with a 45 deg x .03 chamfer and I am putting a .250 OD tube into it and I am trying to put a filleted convex weld bead around it and it keeps erroring out on me. It is saying that they are not contacting surfaces. I have done this several times before, but with two fack threaded parts and that was successfull. Thank you in advance to anyone who can point out to me what I am doing wrong.
RE: weld bead erroring out
On those sizes the Top Surface Delta should be about .005" and the Radius about .03"
SW07-SP3.1
SW06-SP5.1
SW07-SP3.1
SW06-SP5.1
Which surfaces are you selecting?
SW07-SP3.1
SW06-SP5.1
SW07-SP3.1
SW06-SP5.1
Also please confirm that this is an assembly and not a multi-body part?
SW07-SP3.1
SW06-SP5.1
http:
This part is the simpliest part of the assembly. As you can see the bottom two joints were created but the top two keep on error about the radius is too large. Also I did try and put two equal didtance mates on one tube and it started erroring right away. So I assume that more mates on the tube is not the answer. Thanks again for the help.
My guess is that the tube ends do not [u]exactly[/b] line up with their respective holes.
Were the tubes created bottom-up or top-down (in-context}?
Try re-positioning the problem holes in-context to the tube ends. (or the tube ends in-context to the holes)
SW07-SP3.1
SW06-SP5.1
FAQ559-1177: How Do I Make Files Available For Download? ... No Emails Required
SW07-SP3.1
SW06-SP5.1
http://
Thanks again for everything.
http://i
SW07-SP3.1
SW06-SP5.1
SW07-SP3.1
SW06-SP5.1
SW07-SP3.1
SW06-SP5.1
