-58 deg F structural steel
(cross post with AWS)
Does anyone have any reservations / tips / cautions for a structural steel stand that will be shop welded but then placed into service in an environment (outside) that was given a design temperature of -58 deg F (-50 deg C)?
If it was ASME we would be talking impact testing, etc. Is there anything in AWS or AISC about this situation?
ZCP
www.phoenix-engineer.com
RE: -58 deg F structural steel
zcp,
See Chapter 12-3 in the link below for some generalized tips...
http://www.wbdg.org/ccb/DOD/UFC/ufc_3_310_02a.pdf
Also look under the Supplementary Requirements of your ASTM structural material. When you order for structural steel, you need to specify if you want a Charpy V-Notch Impact Test (designated as S5). ASTM A673 covers the procedure for this impact test on structural steel.
