Print Macro
Print Macro
Print Macro
I'm in need a what i think is a fairly simple macro.  The macro would simply plot the drawing sheet to a prn file (check print to file box in the print dialog box)in the directory that the drawing file resides.  I went to record a macro to do this but once the print dialog box comes up solidworks can't record these steps anymore.  Any insight or help is much appreciated.
Kind Regards,
RE: Print Macro
Try this macro - straight from the API help.
CODE
' Preconditions: Drawing document is open.
' Postconditions: Drawing document printed to file.
Option Explicit
Sub main()
    ' Printer
    Const SWPrinter     As String = "\\DOPEY\HP4100-TRAIN1"
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim swDocExt                As SldWorks.ModelDocExtension
    Dim swDraw                  As SldWorks.DrawingDoc
    Dim PathName                As String
    Dim PrintFileName           As String
    Dim nPrintSheets(1)         As Long
    Dim vPrintSheets            As Variant
    Dim DefPrinter              As String
    Dim i                       As Long
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swDocExt = swModel.Extension
    Set swDraw = swModel
    ' Strip off SolidWorks file extension (.sldxxx)
    PathName = swModel.GetPathName
    PathName = Left(PathName, Len(PathName) - 7)
    For i = 0 To swDraw.GetSheetCount - 1
        ' Generate print filename based on sheet number
        ' For example, if drawing document is gears.slddrw and contains
        ' one sheet, then the print filename is gears0.prn
        PrintFileName = PathName & Trim(Str(i)) & ".prn"
        ' Print out one sheet at a time
        nPrintSheets(0) = i + 1
        vPrintSheets = nPrintSheets
        swDocExt.PrintOut2 (vPrintSheets), 1, False, SWPrinter, PrintFileName
    Next i
End Sub
RE: Print Macro
Check this link http://www.lennyworks.com/solidworks/default.asp?ID=20
There is a print drawing macro listed
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right."  -- George Best
