CATIA visualization mode
In order to see big assemblies, it is possible to use CATIA cgr extension. But I wonder (approximately) how many parts can be viewed at a time with a common computer (2Go RAM, 3,6GHz) ?
Thank you
Thank you
RE: CATIA visualization mode
Do you have an idea of the compression between a catpart and the cgr file ?
@ Jackk :Thank you for your quick response !
As far as I know, you can load in DMU few thousands (up to 4, but its very possible to be wrong). If you will search the forum for cgr files, you will have a complete answer regarding the properties of the cgr files.
Another solution is http://w
Fernando
I have already tried the 3DXML Viewer, but i would like to know what is possible with CATIA itself.
Thank you
Some 64 bit testing we have done (dual core amd processor, 8gb RAM, FireGL graphics card) showed that we can easily pull up 12-18000 parts, but the video card starts to struggle. I'd like to try again with a Quadra 4500, but haven't had the chance.
