Has any one ever used living hinges for fine mechanisms?
I am designing a medical measuring instrument and I thought that I could reduce tolerances by using living hinges in its mechanism. This mechanism must be able to move from 1-15mm with steps of 1mm in between. But I am not so sure how accurate it would be. Has anyone ever used living hinges for fine mechanisms, or has some tips on the use of living hinges?
RE: Has any one ever used living hinges for fine mechanisms?
But flexures, made from suitable thin spring-steel strip, yes. At least a couple of times, we replaced a hinged joint with some flexures made from steel pallet banding. A company called C-flex, I think, makes a line of these too, in high-precision interchangeable parts.
