too wide menus in ProE2000i under W2k
ProE Gurus,
I'm running ProE 2000i on Windows 2000 Professional and I have such a problem: All dialog
windows (Analyses, Measure, Open file...) are too wide (nearly 2x) than usually should be. On Win 95
is everything ok. Earlier I have same problem on W2k with menus, but this problem I have
already corrected, I have started to use font MS Sans Serif instead of Microsoft Sans Serif,
which is default in W2k for menus and icons...
I would be delighted if anybody could help me.
RE: too wide menus in ProE2000i under W2k
FONTS_SIZE - (small, medium, large): This option controls the size of the fonts in the text menus.
WINDOW_SCALE - value (0.5-1.0, default =1.0): Scales Pro/Engineeer windows with a given coefficient. Value of 0.85 is usually adequate to allow dynamic menus to display to the right of the Pro/E main window. (taken from PTC PDF file of configuration options)
Recneps
