ETABS for Gravity loading and Foundation reactoin
Hi everyone,
I was wondering if anyone has tips on how to model
a steel frame on ETABS only for gravity loading and estimating foundation reaction. (no lateral force)
The structure is:
-1 storey steel frame (high and low roofing)
-roof joist and deck system
I modelled the structure as:
- all beams & joists = pin-pin
- columns = cantilever gravity columns
running the model this way generates a number of errors and to termination of analysis.
I will be requesting techincal support on this issue from CSI. But, i will appreciate your help.
Inju
The structure is:
Inju
RE: ETABS for Gravity loading and Foundation reactoin
Could you please look at the filename.$og file in the run folder. Just check the part "Percentage of Error"Global Force Balance, which will give you fair idea on Print Static/Dynamic check.
Or
Look at the deformed shape, whether it makes any sense?
or
Look at the mode shapes, if you are asked for it, it may also give some indication
Cheers
