bolt tighten in flanges
i need the tables which show the maximum torques in flanges with different diameters and bolts numbers!
pipes are ANSI 600
pipes are ANSI 600
RE: bolt tighten in flanges
Bolt material should be a factor for your consideration (not only gasket and bolt dimensions).
transfered from duplicate thread 378-185007.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Ie Bolt stress / Strain = E (or Stress / E = Strain) therefor: change in bolt length = Length * (Stress / E)
Knowing the pitch of the threads used, you can determine the rotation of the nut needed.
CreativeVessel
Agree with TGS4, see PCC-1.
Mike
