Resistive Card Supplier / Waveguide Bow Vane Attenuator design
I am looking for a supplier for resistive card used in a Waveguide Bow Vane attenuator. I am not sure even what the material is called! All I know is that the resistance is measured in Ohms per square...
Basically I am trying to come up with a simple design for a variable attenuator, so any help there would also be much appreciated. Tunable from 0 to 40 or 50 dB ideally.
RE: Resistive Card Supplier / Waveguide Bow Vane Attenuator design
_________________________________________________________________________Steve is a one man shop.
Work: 858-486-1810
Fax: rcard
Other: steve vekes
E-Mail: astscy@aol.com
or rcard on a circuit board (preferred location)http://www.ohmega.com/OhmPly.html, this is a large company, although we recently tested their rcard values and they were 35% too high.
There is also a manufacturer in Florida, couldn't find the link, they make rcard in small sizes 4"x8" range.
Window coverings to filter the sun are also rcard.
I think you can also use magnetically loaded RAM glued to a circuit board. Ask the standards about that Emerson and Cuming, Cumingcorp., and ARC.
kch
Presumably the lossy material thickness is relevant because of the skin depth.
It is probably they way the resistive card is used.
A strip of it is placed in the waveguide, secured at each end against one H wall and a pin or screw is used to bow the vane in to the path of the microwave RF, thus attenuating the signal.
A key problem is power. If you want to dissipate a lot of power the substrate stability is critical. I think these things can be made from nichrome films on mylar, but I don't know if it would be good for bending, especially if there were a lot of operations.
Does anyone know of any smaller amounts available anywhere? Say, a couple feet of 100 Ohm per square?
Thank you
Work: 858-486-1810
Fax: rcard
Other: steve vekes
kch
Mark
kch
Also, purchase some home window tinting at your local hardware store. It'll look identical to what you'll purchase for 100x the cost. $20 US for 50 square feet.
I recently purchased two kinds and measured approximately 10 and 30 ohms per square. The window tint also has glue on it, essentially a protective layer to prevent you from scratching the surface. If you scratch Rcard, it'll change your performance greatly, so handle it extremely cautiously since you can not see a scratch and can only measure it electrically.
kch
svmicrowave has a standard product in rcard.
http://www.svmicrowave.com/pdf/resistive.pdf
they give a power rating on them too, which is nice.
5" wide pieces.
kch
