GAs turbine performance calculation -Doubst, i need some help.
Dearl All,
I am trying to calculate the performance charactersitic of a LM 2500 gas turbine in our gas plants. But i have some doubts regarding to collect data, ( i ma taking data from MARK V, system control). For example the temperture T5.4 is valid to consider the combustion gases temperature???,
In my case we have a T5.4 = 744ºC (i think that is low)
Other doubts, i have T1(inlet compressor temperature=24.3ºC ambient) and at discharge compressor (16 stages) P2=13,2 and T2=413ºC, so if you use the theory to corroborate the date is not working.(T2=T1*Rc^(k-1/k))
Rc=Ratio compressor in this moment 13.2 and k (adiabtic coeficient)and our real temperature at discharge is 413ºC
so 413 is not equal to 24.3ºC*13.2^(1.4-1/1.4)
What is happening ,i know that i have to use n(politropic) but even in this way is very different the results.
Best regards
Fernando
Best regards
Fernando
RE: GAs turbine performance calculation -Doubst, i need some help.
T2=T1(p2/p1)^(n-1)/n
n = polytropic index, usually between 1,45 and 1,7.
T1 = Air inlet ABSOLUTE temperature (ºR or ºK)
T2 = Compressed air outlet ABSOLUTE temperature (ºR or ºK)
p1 = Air inlet ABSOLUTE pressure (PSIA or bara)
p2 = Compressed air outlet pressure (PSIA or bara)
Try once again !
thanks for your time, is working better using absolute values. But, how i know the real value of n(1,45-1,7) is a great difference. where i can get a good aproximation for n.
Best regards
The value of the polytropic index "n" has a strong relationship with the refrigeration of the compressed air. Usually, it is determined experimentally.
According to Emden´s equation, n = 1/(k-1).
If you do not have available information of your compressor, you could ask for the test run report, performed on the manufacturer´s workshop or, calculate "n" as a bench mark using the commissioning values obtained during the start up of your power plant.
thread1036-173075: Gas Turbine Compressor efficiency?
If you have suction and discharge Temperature and Pressure, you calculate real "n" and you know "k" you calculate whatever you want...
You might be able to do it using an energy balance around the combustor with the compressor discharge temperature/flow/pressure and the fuel heating value and flow as inputs and assuming an adiabatic combustor.
