Cast iron resisting liquid zinc
An ingot rotating distributor, wheel shaped is currently made in DI (sg )ferritic iron but it is corroded by liquid zinc supposed to be transferred to ingot molds. Any suggestion for a different cast iron or alternative material? Thanks
Julio
RE: Cast iron resisting liquid zinc
You can try flake graphite iron instead of SG iron for the application. What material is the ingot mold? Use the same material if possible.
" All that is necessary for triumph of evil is that good men do nothing".
Edmund Burke
Isn't Zn attack related to the Si content?  Don't they use low Si carbon steel for galv equip?
Maybe you need to look at those requirements.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
