Vacuum condensate return system
Greetings,
Would like to know the reason for the inclusion of a bypass
line at the outlet of a L.P. steam coil on an AHU.
Obviously a strainer is in front of the F&T Trap on the
return piping but after the F&T a 3/4" line runs back to the
coil outlet. This line is fitted with a check which is opening
towards the steam coil.All the AHU's are piped this way and
the return main is running to the accumulator tank of a
65K Dunham Bush Vacuum Tank.Can anyone that is sure of the reason for the inclusion of this bypass take a few minutes
to explain.
to explain.
RE: Vacuum condensate return system
