Best pipe material for submerged water service
I am designing a pressurized water system that will be submerged in lake water. It will be 2 to 6 inch steel. I would like to know if I should specify stainless (if so, what type) or carbon steel with some kind of coating (paint or hot dip galv.) Do I need to coat inside and out? The system will supply a network of spray nozzles, so I would like to minimize their plugging with rust, etc. Thanks in advance.
RE: Best pipe material for submerged water service
How deep?
How much internal pressure?
What do you do when the lake freezes?
Mike Halloran
Pembroke Pines, FL, USA
The nozzles spray lake water onto the back side of submerged wedgewire screens to remove leaves, etc. It's an underwater backwash system. The deepest nozzle is 12 feet down, and I'm supplying 80 psi water. It works great--we've tested it. The system is raised during the winter and mothballed. My client is concerned that the pipe will corrode internally and rust flakes will plug the nozzles, which have 0.14 inch orifices. So I'm looking for alternatives for pipe--stainless, painted CS, hot dipped galv., etc. It can't be plastic. Thanks for the interest.
My guess is though that you will have better luck doing this economically with epoxy coated carbon steel. Get pipe that is shop coated inside and out. cut, fab, weld, and then hand coat the joints. Every fall when you pull it out you can inspect and repair.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Thanks for the reply. What exactly is a lean duplex stainless grade?
On a microscopic level these alloys are a mixture of austenitic and ferritic stainless steels. They have some properties of each, and some advantages. They have been designed so that the corrosion resistance of the two phases is nearly equal. These alloys are much stronger than 3XX series austenitic alloys, and much better at resisting chloride stress corrosion cracking. They are easier to form and weld than ferritic alloys, and more ductile.
The traditional duplex grade is 2205 (22% Cr, 5% Ni, 3% Mo doesn't get listed).
The lean alloys have lower alloy content and lower cost. Alloys like LDX2101 and AL2003.
The LDX2101 material cost is less than 304 today. It is an easy decision, if you can find the product forms that you need.
Rust never sleeps
My initial suggestion was "Flexpipe":
http://www.flexpipesystems.com/about.html
It does have "plastic" though. Would something like this be worth investigating for your application?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Rust never sleeps
As for stiffness of the system, by modifying the construction of the pipe in critical areas additional stiffness can be incorporated and this can be checked using an analysis program such as Ceasar. In addition the pipe joints are not necessarily flanged so assmbly time can be as low as a couple of minutes per joint.
Hope this helps.
