Bill of Material
Bill of Material
Bill of Material
Hey everyone
does anyone here know how to traverse a BOM via VBA in Solidworks?
RE: Bill of Material
Enter "traverse a BOM" in the Google search at the top-centre of this page. Make sure the Eng-Tips Forums option is selected.
cheers
SW07-SP3.1
SW06-SP5.1
thanks, I think I may have found a thread that will help.
ok, I need a bit of help with this code...
I am using the code from this thread, [url]http://eng-tips.com/viewthread.cfm?qid=20992[/url] and modified it a bit.
Here is the code below, I can not get it to find the BOM. Any help would be greatly appreciated.
CODE
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swPart As SldWorks.DrawingDoc
Dim swView As SldWorks.View
Dim swBOM As SldWorks.BomTable
Sub ReadBOM()
    Dim ret As Variant
    Dim i As Integer
    Dim iItems As Integer
    'Get Document
    Set swPart = swApp.ActiveDoc
    'Get Drawing Template (first view)
    Set swView = swPart.GetFirstView
    'Get the BOM
    Set swBOM = swView.GetBomTable
    'Find the BOM - must find the view that contains the BOM
    Do While swBOM Is Nothing And Not swView Is Nothing
        Set swView = swView.GetNextView
    Loop
    If swBOM Is Nothing Then
        'Screen.MousePointer = vbDefault
        MsgBox "Can NOT find the BOM on the current drawing!"
        GoTo CleanUp
    End If
    'Attach to the BOM
    ret = swBOM.Attach2
    If ret = False Then
        MsgBox "Error Attaching to BOM"
        Exit Sub
    End If
    iItems = swBOM.GetRowCount - 1
    For i = 1 To iItems
        MsgBox swBOM.GetEntryText(i, 0) & "|" & _
               swBOM.GetEntryText(i, 1) & "|" & _
               swBOM.GetEntryText(i, 2) & "|" & _
               swBOM.GetEntryText(i, 3) & "|" & _
               swBOM.GetEntryText(i, 4) & "|"
    Next i
    swBOM.Detach
CleanUp:
    Set swApp = Nothing
    Set swPart = Nothing
    Set swView = Nothing
    Set swBOM = Nothing
End Sub
That's old code, used for getting Excel-based BOMs.  To access SolidWorks BOMs (Introduced with '05, I think) you have to use different calls.
1. swBOM should be declared as a Sldworks.TableAnnotation rather than Sldworks.BomTable
2. Instead of swView.GetBomTable, you need to use swViw.GetFirstTableAnnotation.  If a table is returned, you need to test and see it is a BOM table annotation with swBOM.Type.
That should be enough to get you pointed in the right direction in the SW API help.
got it to work, thanx for pointing me in the right direction.
No problem.  On re-read, my post looks a bit brusque.  Sorry about that.  I was trying to get gone for lunch.  smile
not a problem...
