How much Sodium Hypochlorite?
I'm designing a 14 home water distribution system for a subdivision.  It's a 50gpm well feeding into a tank house.  Pressure, storage, and Cl contact time will be accomplished using two 1400 gallon pressure tanks operated in series.
I plan to inject sodium hypochlorite into the system prior to the pressure tanks.  Any idea how much Cl solution I can expect to go through?  The owner will likely lease a small injector pump from his chemical supplier.  I'm trying to figure out how big of a storage tank he'll need for a 30 or 60 day supply.  I need 1 mg/l free.
Just looking for an approximate educated guess.
Doug
RE: How much Sodium Hypochlorite?
First, you have to disinfect the new system according to AWWA Standard C 651.
For normal operations at 1 mg/l, you would probably be interested in using carboys as you need only 18 gallons per month of sodium hypochlorite.
http://www.cleanwaterstore.com/help/chlo_worksheet.html
got any iron, manganese, or sulfur? they can multiply your demand
Hydrae
Good post Hydrae
thanks guys.
Dont forget ammonium! It eats chlorine 10:1, so even a 0.1ppm makes a big difference to your chlorine demand
