What is being add to the new Compress Built 6253
Tom:
What is being add to the new Compress Built 6253; Upcome New features in Commpress?
RE: What is being add to the new Compress Built 6253
Our programmers are currently updating COMPRESS for compatibility with Microsoft Windows Vista. This required that a lot of our programmers' tools (compilers, etc) be upgraded as well. This has been a very long and painful undertaking. Some of the program language coding that was accepted in earlier compilers is now rejected by the newer compilers; this required that the statements be rewritten.
So, the biggest task or new feature for "build 6253" will be Windows Vista compatibility. Aside from that: there is always the bug list to work on, and development of additional features for the heat exchanger program always continues. But we always like to provide new features for the basic COMPRESS program also. We plan to release lifting/turning trunnions this year. We also need to incorporate the 2005 Edition of the NBC-Canada wind and seismic code.
Tom Barsh
Codeware Technical Support
I think you had mentioned at one time that codeware was looking at adding an elliptical manway option to Compress. Is that still in the plans for the next build?
Vince Petrucci
Client Project stecification:
Request to FVC TYPE "Q", Insert Type, or Butt Weld Nozzle be added to Nozzle Compress Pressure Vessel Software by Codeware Type 13 (Forged Vessel Connections
Products: Insert (Q) Nozzles
The FVC TYPE "Q", Insert Type, or Butt Weld Nozzle is available through 24" sizes meeting the ASME B16.5 standard (all pressure classes). FVC can also meet the specifications of ASME B16.47, Series A & Series B. The "Q" style nozzle can be furnished with either the "F" style or "V" style body (depicted in shaded view above) as a flat bottom, spherically or cylindrically curved as depicted in the shaded area of the drawing above. FVC maintains a large raw material inventory of SA105 and some of SA350-LF2, SA182-F22, and SA182-F11.
L S THILL
Tom Barsh
