Bolt torque values
Bolt torque values
Dear members
I need a clarification on torque values .
I have a torque table which says that
for 8In bolts torque values are Min 8Nm and
Max 10 Nm .These values are given under a table column which reads serrage electrique / rondelle contact
Similaly for same size under serrage mecanique / rondelle onduflex the torque values are min 15 Nm and max 18 Nm
Can anyone explain why the torque values are different/
Is it something to do with methods of torquing?
Sree60
Sree60
RE: Bolt torque values
Maybe one set of figures is for dry assembly and the other for lubricant assembly
regards
desertfox
serrage mecanique - mechanical connection
mintjulep
can u explain further? What do they signify in this context-mechanical and electrical connection ?.
something to do with method of torquing?
Thanks if u can clarify
sree60
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thanks for the help
sree 60
