Groundwater Well Removal
We have three groundwater monitoring wells that need to be abandoned and removed from the ground to a depth of at least 26' below ground surface. They must be removed due to a future landfill on top. The wells have multiple steel casings, each with the annular space filled with grout. From the inside out, you have 4" steel, grout, 12" steel, grout, 18" steel, grout (25" bore).
The overall well depth is 180' or so. Short of pile driving it further into the ground, what are our options for cutting the casings at 26' deep and pulling it out? Open excavating to get to that level will be challenging, expensive, and dangerous. I'm thinking a shape charge explosive to cut the pipes, but that's just from the "wouldn't it be cool" aspect.
RE: Groundwater Well Removal
Otherwise AIR LIQUIDE ( compressed gases supplier ) has cutting torches that can be lowered in a hole to cut a steel pipe.
Here is a method called overdrilling with a hollow stem auger:
Well Decommissioning
Measure the well’s depth before it is sealed. Do this to ensure that no obstructions might interfere with effective sealing. Record static water levels.
To properly seal a well:
• Remove (pull or overdrill) or drill through the well casing with hollow stem augers);
• Cut off casing 2 ft. below grade and grout in place.
Note that removal is the preferred method for well abandonment.
Use bentonite, neat cement, or a bentonite/cement mixture as the primary sealing material. Use a single, continuous operation to place such material upward from the bottom of the well to within 2 ft. of the surface. Backfill the remaining 2 ft. of annular space with materials that match the existing surface conditions (i.e., soil, asphalt, concrete).
https:
