Material for fire resistent Thermal Break between aluminium extrusions
Hi
I am looking for an appropriate materials to use for extruding  into a "splice" shape that binds two aluminium profiles together. The only snag is the splice needs to be as fire resistant as possible. The design is similar to a thermal break splice used in external glazing frames.
Alternatively is there a company who specialise in high tempeature thermal break assemblies for a aluminium extrusions. (preferably in the UK or Germany)
Logikman
RE: Material for fire resistent Thermal Break between aluminium extrusions
These any use ?
http://www.envirograf.com/products/product076.html
Google for "Intumescent sealing Aluminium Profiles" gives a few hits to investigate - not sure whether you need fireproofing or high temp application...........
Cheers
Harry
I think that silicone elastomer will meet you needs from the little information you provided.
