opening step files
opening step files
Hi all,
Can anybody help me with the following:
when I open a stp-file with the assembly template, it seems the conversion is going allright, however I don't see anything in my 3d-model!
Are there any 'safe'-options on opening a step-file? (so it always works)
Evert
SoldEdge V19
Windows XP Pro
RE: opening step files
Are you getting parts listed in your edge bar?
Patrick
If I continue I get the folowing message: multiple bodies found during the file open process. I then see the model with part copies.
When I open the same file with the asm-template I see nothing. There's no model and there's nothing showing in the assembly pathfinder tab. The log-file states there are solid bodies created.
Can anybody help?
Evert
SoldEdge V19
Windows XP Pro
the asm seems to consist of construction bodies
only. The EdgeBar should show at least one item.
Select it them RMB --> Show/Hide Component --> activate
Surfaces.
HTH
dy
