adding sheet numbers to print label
I've got a quick question for you guys - how can I add page sequence numbers to the label that prints oin the border of my drawings? This may sound redundant but my customer uses a non-standard drawing numbering system that does not include the normal (sht 1 of 4, sht 2 of 4...) type of number. This means that out in the field you could lose the last sheet(s) and never know it. We can't change the format but could probably add something in the border label without an issue.
Thanks in advance for your anticipated responses.
Kimb12
Kimb12
RE: adding sheet numbers to print label
-Hora
¤t_sheet
&total_sheets
Ben Loosli
Sr IS Technologist
L-3 Communications
If you print to PDF (as we do).
You could add a water mark to the pdf only.
This would eliminate the need to change the format.
I saw an article on how to do just that. I just need to remember where I saw it......
Cheers,
JW
