local coordinate system
hi everybody,
i would like to define a local coordinate system in abaqus/cae version 6.4 that is able to move with the deformed body. I want to use it for applying boundary conditions on a moving surface, that needs to be plane during the deformation. can anybody help me?
thanks in advance,
michael
RE: local coordinate system
If you need a surface to remain plane during deformation, you might be interested in defining an Equation based on the nodes of that surface.
See:
ABAQUS/CAE User's Manual ->15.14.7 Defining equation constraints
You first need to create a new Datum CSYS (think icon was still on the right). Then when you define Boundary coundition, use the new Datum you creates instead of the Global.
Try this.
(1) create reference point on the face to remain planar
(2) create a cartesian csys located at the reference point and oriented such that axis 3 is normal to the planar face
(3) create kinematic coupling: control point is the reference point from (1), surface is the face to remain planar
(4) create a BC, with the local csys from step (2)as the reference and fix in U3
It's pretty easy to do and very easy to create a macro/plugin to automate.
thanks for your replies, i think it will work soon.
