Implicit equations
Implicit equations
Implicit equations
How can i solve implicit equations in a simple matter without separating the two sides first? I want to solve it directly...
RE: Implicit equations
Select the variable that you want to solve for (on either side) and then in the Symbolics menu select Variable|Solve.  The implicit equation needs to have a Ctrl+= sign between the two sides.
But what if i have a range variable on the one side? I get this message:
This matrix must be square. It should have the same number of rows as columns.
I excpeted to get a range variable as an output when i used the Find(*) command. It certainly is a same amount of answers??
