Setting the 3GB Switch
I'm looking for the file boot.ini, which can be modified to allow allocation of 3GB. Where is that file located?
Pingen
Pingen
RE: Setting the 3GB Switch
The file is normally located on the root C:\ an is hidden. So you must set in the the file options of your explorer the option for hidden files.
Pingen
I finally found the file.
Pingen
