Range of best drive slip of racing tires
Hello!
I'm searching for some Information about the range of the best drive slip of racing tires to optimize a racecar tractioncontrol system.
A diagramm
coefficient of static friction = f(drive slip)
or something would be fine...
Thanks to all
Regards, Thomas
RE: Range of best drive slip of racing tires
Good luck
10-30% for a production tire, but it is very dependent on a host of things.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Any flat track test data will be useless because the track surface you actually run on will have a big effect.
It's very easy to calculate slip ratio and plot force against it from a data logger.
I'd do this. Anything you'll find in books or papers will be of academic interest only.
Ben
Well, I think I'll try to get some data from my tire manufacture. The support is quite good there.
My TC contains up to 12 mappings, so I can try different slip ratios quite easily during a track test and have a closer look at the logged data.
We'll see... winky smile
