Solidworks 2007 VS dual core
hi there
can solidworks 2007 take advantage of intel's Dual core technology?
thanks.
RE: Solidworks 2007 VS dual core
You'll see the advantages primarily if you use PhotoWorks to render (or render an animation), where all your processing power will be used.  Otherwise, SolidWorks makes use of multiple cores, but in most cases not very much (such as general modeling).  I have a dual-core FX-60 (AMD), and I like having multiple cores because I often render animations and have other programs open while using SolidWorks.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
