How to smooth an optimized mesh?
I have written a script that does load path analysis by removing elements that are not in the load path. I would like to improve the visual appearance of the optimized mesh. Any suggestions for either creating a smooth cad geometry from the mesh or modifying the mesh to make it smoother and less jagged? Here is a picture that shows a simple sphere with a point load at the top and supported at three points at the base:
Principal - http://www.OnlineFEASolver.com
General FEA Consulting Services
RE: How to smooth an optimized mesh?
The process you'd like to use is called annealing, but the practical difficulties associated with implementing it are hard - as you move nodes the element quality drops.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Also search for the "MARCHING CUBES" algorithm. It's relatively easy to implement and computes a smooth surface from the relative densities of the elements.
Alex
The "MARCHING CUBES" algorithm works for hexahedral meshes. But if you understand how it works, you should be able to write your own code for tetrahedral meshes.
