Fastening stainless steel hinges to glass fiber
Hi! I need to design/fabricate some fiber glass pressurized cabinets that will be utilized in offshore, hazard, corrosive enviroments. My first question is regarding the resin, should I use vinyl ester? my supplier recomends it as the best option against epoxy or polyester resins for this type of enviroment. My second question is how to fix/bolt the stainless steel hinges. I'm very concern about creep; or the material just cracking as I bolt the hinge. Should I add a molded stainless steel insert? is this feasible? or, is it better to use some adhesive instead? or to "ducktape" the hinges with reinforcement fabric tapes?
Any suggestion will be more than welcome.
Thanks in advance!
Aldo
Thanks in advance!
Aldo
RE: Fastening stainless steel hinges to glass fiber
Some types of stainless steels are good in a salt water environment some are not. The problem is not "rust" but chemical attack on at the grain boundaries resulting in "brittle" crackage.
I am sure Metallurgical will comment further...
http://www.clickbond.com/index.php
Thanks again!
Aldo
Some MIL specs would not allow a structural joint in composite part that relied on secondary bonding without a 100% redundant mechanical retention back up. Neither would I.
