Sticking Safety Valves on Refrigeration Packages
Soft seated Safety Valves on Refrigeration duty (actually handling the refrigerants) have a history of sticking has anyone knowledge of Safety valves on the market that get round this problem.
RE: Sticking Safety Valves on Refrigeration Packages
Please contact me on 0117 9306116 for futher infomation.
"Unique sealing system which prevents sticking and repeat operation"
Should have read.
"Unique sealing system which prevents "sticking". The valve will also give repeat operation which is a benifit over other Refigerent Valve manufacturers.
The more you learn, the less you are certain of.
