Return Condensate Alkalinity
What is the physical/chemical process that provides for a very high alkaline environment in return condensate?
Can this alkaline environment be reduced by artificially lowering steam pH?
Or are there limits to how low the pH can safely be taken?
Tom
RE: Return Condensate Alkalinity
A high pH, say 9-10, is perhaps intentional (via volatile amines added to the boiler feedwater & desirable to prevent corrosion, especially in a vented system that can absorb CO2 from air.
Please provide details of system & pH values.
