m&Y factors for gaskets
I am new at this stuff so I may be asking a stupid question. I have seen the terms m&Y as well as cg&Sg both used when describing a gasket. m&Y seems to be more common, is there a difference between these terms? Can they be used interchangibly?
RE: m&Y factors for gaskets
Refer to ASME Section VIII, Div. 1, Appendix 2.
If you don't have the Code you can look into the websites of gasket manufacturers. Here's a few...
http://www
http://www.flexitallic.com/pdf/designCriteria.pdf
www.garlock.com
www.lamons.com
