Overiding automatic snap-to when inserting text
Is there some sort of override of the automatic "snap-to" function when inserting text. It seems like every time I try to insert text, it wants to associate itself to other text entities. Once it picks up on the other entity, it holds on with bulldog tenacity.
Is there a user setting to prevent this or a hot key combination to override?
RE: Overiding automatic snap-to when inserting text
After you create your note, you can hold down the ALT key and move the note without association to existing objects.
HTH
John R. Baker, P.E.
Product 'Evangelist'
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
The ALT key does disable the snapping function for me when adding/moving a note if it is pressed and held before a snap occurs. That is, if I pick/create a note, press and hold the ALT key, then move the note, it moves or inserts with no problem.
On the other hand, when I try to move or insert a note without the ALT key and the note tries to snap to a location, then at that time it is too late to use the ALT key. Once it has picked up on a snap point, I usually have to go ahead place the note with its new association and then re-move it, or cancel the move and try again.
This is only a problem when there are a number of notes in the are I am working. If there are only a couple of notes, then the note in transition can be dragged far enough to lose the snap without picking up a new snap from another note.
Have I made this confusing enough or should I try harder?
Kevin
John R. Baker, P.E.
NX Product Line
UGS Corp
Cypress, CA
http://www.ugs.com
Exactly what I was looking for. Thanks
