WELDED WATER COLUMN
WELDED WATER COLUMN
WELDED WATER COLUMN
I need guidence that,
Are there any ASME code applies to welded water column, which will going to mount on ASME I (high pressure steam) boiler?
What marking/stamping require on welded water column as per ASME I?????
Also waht markings require on gauge glass body as per ASME I?
I need your guidence ASAP.
Thanks in advance
MIhir5577
RE: WELDED WATER COLUMN
Review PG-60.2 in Section I of the ASME B&PV Code.
Thanks for quick reply.
But i also want some clarification as per PG-11 - Standard Pressure Parts,
That if anybody built welded Water Coulm as per PG-11, and if there was no any markings (Heat #, Matl spec.  etc..) on all welded standard parts (Like Caps, Ring- Joint, extenders etc.), than is this acceptable or not?
As per PG-11.3, no Matl. test report, MDR, inspection etc.. require.
Can we accept this welded water column without markings on all std. welded parts?
Pls. i need calrification/Guidence ASAP.
Mihir5577
