View Scale
View Scale
I must be having a blonde moment and need some help...
How do I link drawing view scale to my title block scale displayed on my drawing? Currently it's linked to sheet scale.
SCALE: $PRP:"SW-Sheet Scale"
What's happening is when I scale my view, the value doesn't change in the title block. It stay's static because it's link to the sheet scale.
Is there a property like this?
SCALE: $PRP:"SW-View Scale"
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: View Scale
Your not having a blonde moment. No, because you can set a view's scale to the sheet scale. If your view scale is the common scale for the drawing, then simply assign that view scale to be the same as the sheet scale its properties, then adjust the drawing's common scale using sheet scale (linkable with $PRP:"SW-Sheet Scale").
If you do wish to list a view scale separately from the sheet scale, you can use this macro by Regg:
http:/
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
