Winding cleaning practice
I would like to know your opinion about the distinct pros and cons using chemical, organic(blasting), water/soap(detergent), or cryogenic liquids for motor or generator winding where machines are prone to grease and petroleum base oils contamination. The machine is open drip-proof enclosure in diesel power plant.
What choice and best experience had address to this matter?
"Whenever you are asked if you can do a job, tell them, certainly I can! Then get busy and find out how to do it." Theodore Roosevelt.
RE: Winding cleaning practice
Sometimes I only open my mouth to swap feet...
