another B.O.M question.
I don’t know how this is happening. I will insert my B.O.M., then do any adjustments then go about the drawing doing my work then the item #1, 2 and some times 3 will go away and the numbering will start from there. When I go to the B.O.M. contents my missing # will not be there and at the bottom of the list there will be spots that are blank that you cannot do any thing with. Please help. This is such a head ache.
RE: another B.O.M question.
Which SW version and SP?
SW07-SP3.1
SW06-SP5.1
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000 / Lava Lamp
www.Tate3d.com
Jack L. Tate says: "Right-click... It's friggin' magic!"
FAQ376
Can you post a small sample assy which you are having problems with? (See FAQ559-1177: How Do I Make Files Available For Download? ... No Emails Required for details)
SW07-SP3.1
SW06-SP5.1
Also, is your BOM linked to a particular drawing view?
DO NOT modify the BOM tables at anytime if it's link to a view. You must drop the link if you do any edits or insert your own table into the drawing. If you need to add items to the link BOM's, they must be added to the last/end item automatically generated by SW. Manually inserted items or modifications will be wiped out every time doing rebuilds and asking for headaches.
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
