Light-gauge steel framing with 316SS Studs
Does anyone make light-gauge 316 SS studs for walls?
I was hoping to use them for a lightweight shaft wall at an existing indoor pool for a college.
RE: Light-gauge steel framing with 316SS Studs
I hope not.  Weak, expensive, and not resistant to attack in pool enclosures.
Call Catherine Houska at TMR, 412-369-0377.  They are a consulting firm and she specializes in architectural applications of stainless.  She will know what is available.
Maybe someone has started doing this work in a lean duplex grade.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
SteveGregory,
Cooper B-Line has uni-strut available in steel, aluminum, 304SS, and 316SS.  Only the steel product has a size with a 3-1/4" channel, but a pair of the 1-5/8" stainless steel channels might be fitted back to back.  The 316SS struts would be in 12 ga or 14 ga.  Maybe single l-5/8" strut is  adequate for the shaft wall.
Some available finishes are galvanized, copper paint, or PVC coated.
www.b-line.com/product/Strut/Index.asp
