Making a spline shaft with the Engineering Handbook
Hello everyone!
What I would like to build is a shaft with 4 or 5 different areas. Spline shaft - normal shaft - gear - shaft with key- normal.
More or less something like this http://www.crownpower.com/image007.jpg
I can make different types of shafts with the shaft-function except the spline shaft with transition. The only way I found to do it is with the "spline shaft" function. This will only make a straight shaft without any transitions to other types of shaft. something like this one: http://www.bareco.com.au/pics/ptopics2002/pto11a.jpg
How have you solved this problem?
I would like to learn better how to use the Engineering Handbook from SE. I've read the included documentation but still can't build more complicated parts.
Is there a tutorial or excercices in the net?
cheers,
Claudio
