Mathlab Codes for Planar Invert "F" Antenna on a finite ground Plane
I have tried using Supernec to do simulations for an inverted F antenna.I have had problems getting the mathlab codes for this antenna.Any suggestions would we welcome as regards getting directions to getting this code.Thank you very much webmaster for this forum.keep up the good work.
