parameter >file>export
Greetings
I am using WF2 and am trying to figure out how to use the export file that can be create in the paramter "construction"box. My intention is to change parameter assignments in parts I used a "temporary" start part in a new assignment untill I got drawing and start part formats correct for this new customer. I want to up date the 40 or so parts I have completed to this point to the new parameter file with out manually doing this by deleting the old and typing the new individually.
TIA
Norb
TIA
Norb
RE: parameter >file>export
bring your parameters in as relations , then after running the check relations... you can delete them.. you can mapkey the whole thing
I am not much of an administrator of this type when I use pro/E, however I think your solution is what I need.
I have copied your mapkey to my config file and then run it and it did not work. I am curious about this statement in your reply and would like further detailed information as a rookie trying to understand and accomplish this.
format of file to read in for parameters;
my_ans=yes come in as yes/no
my_str="string" string
my_val=5 real number
What do I do with this information?
Norb
Just make sure you have the right part active when you insert the table and that all the parameters are there.
If you do add the table to a drawing where the parameters have not been added to the part it will prompt you for parameter info but it will not create them in the part.
On any drawing create a table then double click and enter the &PARAMETER_NAME and then select the table and choose
Table > Save Table > As Table File
Table > Insert Table > From File
Michael
I am wanting to replace the existing parameter ile with the newly created one.
The method I'm talking about will only add params... I think you will have to manually delete any existing ones if you don't want them anymore
