3by3 Newton-Raphson Method
Hi, I'm writing a program in C that creates a simple model of the forces within a tow cable being pulled through the ocean by a ship. In my force analysis I have three non-linear equations with three unknows. To solve for these unknowns I would like to use the Newton-Raphson method. I've found a lot of information on the simple single unknown form, but haven't found much for solving three unknonows using a 3by3 matrix.
Do any of you know of any already made functions that I could use so that I eliminate the need to reinvent the wheel?
Thank you,
windell747
RE: 3by3 Newton-Raphson Method
Isn't that better known as the "Newton-Multidimensional" method?  ie. calculating corrections via a Jacobi matrix.  You might try searching for an algorithm by that name.
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
