.0685mm to .0762mm I.D. hole
My company is considering a production job on a nozzel. The problem we are having is with the counter bore & the I.D. hole that is going through the counter bore. The material is with 303 ss. O.D. is 6.995mm. The conter bore is .250mm +/- .25mm , depth 2.25mm, with a circular runout of .025mm to the O.D. The I.D. is .0685mm to .0762mm, length is 1.250mm with a true position of .025mm to the O.D.
Any advice, suggestion, machine's capeable of doing this, or any names of companies that do this work would greatly be appreciated. Thank you in advance Brad
RE: .0685mm to .0762mm I.D. hole
Mike Halloran
Pembroke Pines, FL, USA
Yes we already have a Swiss-style CNC and tried it on there, the problem is with the smaller I.D. hole wich is which is aprox .0025" to .003" in diameter. We have even tried sending the part outside to be lasered but they kept blowing the hole out on the top. Thank you for your input anyways.
Brad
Don
Kansas City
Brad
I had a male feature a little smaller than that made for a molded part once. I.e., a stepped pin, with the small part at .002" diameter. It had to be single pointed on a super- precision CNC machine kept in a temperature controlled room, and they had to let the spindle run for an hour to stabilize it, that sort of thing.
Mike Halloran
The counter bore is easy, just don't machine it at all, since the tolerance is 0.25mm +/- 0.25 mm (i.e. a 0mm hole is acceptable :)
National Jet Company, in Maryland, USA, http://www.najet.com/ can do this job for you. They specialize in tiny, deep holes. Ask them for their business card, used to come with a hair taped to it, and the explanatory note that there was a wire threaded thru a hole drilled in the hair. You had to look under a scope to see the wire.
Thanks Brad
Try a different laser vendor. Some of them only have giant photon cannons, and can't do delicate work.
Mike Halloran
will hel;p with the small drill, as will making a "starter hole drill" to get the hole started straight, spinning the part the opposite direction of the drill whil spinning the drill will help "fool" the tool into not walking...
wither way it's one tough hole...
Electron beam hole drilling may be another option.
You may wnat to check out the following. I would give them a call.
http://www.smaltec.com/pathway.cfm
