Stuff just stops working
I can't recreate this problem, it just seems to happen randomly...
After working for a while in SW, I'll suddenly lose the ability to save or use shortcut keys. My SpacePilot will cease to work and my standard views will disappear. It's not locking up; I can still zoom in/out and pan with my mouse.
Any thoughts?
Any thoughts?
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
RE: Stuff just stops working
SW07-SP3.1
SW06-SP5.1
Jeff Mirisola, CSWP
CAD Administrator
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Jeff Mirisola, CSWP
CAD Administrator
Jeff Mirisola, CSWP
CAD Administrator
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
Here are a few more ideas:
Have you verified that your memory is good, and that you have sufficient swapfile size relative to your RAM?
FAQ559-507: Alternative to try before reinstalling
FAQ559-884: Have you Cleaned out your TEMP Folder out lately?
Also, when doing a complete Uninstall / Re-install, is it OK to use your copy settings wizard prior to the uninstall? or does this bring back possible corruption into the new install?
Tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
If it is a bad USB connection, why would it affect my keyboard shortcuts?
I'm going to pay close attention today in case it happens again. I'll also be sure to get the stats from the task manager.
Thanks all!
Jeff Mirisola, CSWP
CAD Administrator
